- 1 Jun 2010
- Bedford
Hi guys
I just received side panel for my case. I noticed it had some scratches and dust was building up. So I applied tooth paste method to a section of the window and then wiped it off with a dry cloth (so stupid of me). Next thing you know that section became cloudy with more scratches. Then I used soap water and cleared it with dry towel but it still didn't go away
. I am wondering if a good acrylic window cleaner can get rid of this problem and if so, could you please spec me a good acrylic window cleaner. many thanks.
Edit: By the way it is Storm sniper window panel.
. I am wondering if a good acrylic window cleaner can get rid of this problem and if so, could you please spec me a good acrylic window cleaner. many thanks. Edit: By the way it is Storm sniper window panel.
