Active Directory - DNS problem
1 May 2006
Bristol, UK
Morning all.
I'm going to be using today to set up Windows Server 2003 with Active Directory on a spare box. I've done lots of testing with virtual machines and I've got a setup checklist written down.
The one problem I'm having is with DNS. Normally a single server would also be connected to the internet and be used for routing and NAT. However, we already have a linksys router (running DD-WRT) which does a damn fine job of distributing our internet and the powers that be are reluctant to shift it since it's only a little project for myself. This means that the server will be connected to the router as a client. So all DNS requests from my desktop for example, go straight to the router and out to the internet (via our ISP DNS's), completely ignoring my server thus resulting in a whole host of problems.
DD-WRT is able to act as a DNS server, so I guess one option is to replicate the entire DNS structure from the server to the router, which won't be too laborious since there will only be 2-5 workstations. Failing that I could add the server IP to the 'dns servers list' on the client machines.
Was just wondering if anyone else had any other methods that are cleaner, for example any dns requests for 'locallan.example.com' (for example) are routed straight to the server.
TIA,
Freakish_05
You have to have the AD server as the primary DNS. You then set up a DNS forwarder on the DNS server (which would be your router's IP) which is where every DNS request it cannot serve is sent to.
That way all local stuff uses your AD server's DNS and it then forwards all Internet related DNS queries off to your router.
If I were you, I'd use the server as the DHCP server and in the DHCP options set the DNS IP to the servers IP and the gateway IP to the routers IP. That way all the clients will be made to see the server as the primary DNS but will also have their gateway IP set to the router...
Aye that's the way I'd do it. Or, seeing as DD-WRT is pretty good, that should also allow you to specify your own DHCP options.
Either way, you want the gateway option to be set to your router's IP, the DNS option to point to the server and a DNS forwarder set up on the server :)
