active displayport help
5 Jan 2010
iv got a sapphire active display port with the intention of running 3 monitors from my 2 5870s. i cant get it to work it wont detect all 3 monitors in ccc any 2 will work but not 3 i assume its my fault any ideas??
thanks in advance
Are only 2 being detected or does it see all 3 but you can only use 2? If the former then make sure you've plugged the DP in properly as I had the same problem and I hadnt pushed it in far enough. If the latter then you'll prob need to add them to a group which you do by going into CCC and in the desktops and displays section click the arrow on the monitors and select create group.
