Active or passive monitors?
17 Mar 2004
Hi all.
Looking for a new set of monitors for my home studio. Mainly going to be used for when i'm DJ'ing, and a bit of producing.
At the moment i'm using 2 Behringer Truth active monitors.
Should I replace them with some active or passive monitors?
I'm thinking active as I can plug them in and i'm away but as i'l be using them for production too i'm wondering if i'l get a more accurate sound with being able to adjust the amp etc.
Any recommended models would be good?
I don't mind going second hand - got about £250 for the speakers.
Cheers.
Your right in your thinking, active should suit better. The amps in the speakers are matched perfectly to thier drivers and there are usually a few controls to set them up according to where they are in the room (near walls, corners etc). Using active, you should be able to get a very flat, uncoloured sound quite easily.
I got a pair of Samson Rubicon 6a active monitors (with ribbon tweeters) a couple of weeks ago, and I am very pleased with them so far. They have volume controls on the back.
