6 Jun 2008 at 14:43 #1 smokedog smokedog Soldato Joined 28 Jul 2004 Posts 5,865 Would you buy a slide phone without active slide? By active slide I mean you are able to answer and end calls by opening and closing the slide.
6 Jun 2008 at 18:02 #2 chiggz chiggz Associate Joined 6 Jul 2007 Posts 1,530 Location Chiggzwick, London i disable it.. cos i usually close the slide once i've used it to dial/select the number
