Acustic Solutions?
20 Oct 2002
Oxfordshire / Bucks
Just had a look on OcUK
Not sure what to get, maybe a DIY store? rubber material?
my PC is sitting ontop of a dead PC at the moment to give it some hight, but boy does it resonate.
need to damen it down if possible! walking in the dineing room all you can hear is the fans! lol
buy some quiet case fans :) I bought some acousti foam stuff from ocuk years ago and it took a reasonable amount of noise from my ti4400 fan which I thought was loud.
Whatever you do, avoid the evil that is 'Akasa PaxMate'.
It's probably the cheapest, and best way to ruin a case. Absolutely terrible stuff, doesnt make much of a difference and certainly isn't worth the hassle to remove.
Maybe try get something like DynaMat like builders use? Might be an option, but I'd probably stick it down with double sided tape :)
The only case fan I have is the one on the back.
the most NOISYEST fan in my PC is on the GFX, ATI Radeon X800, its louder than the CPU fan, and thats the Zalman CU 7**** something (cost me £40! i think) PSU on the other hand is quite really.
Thinking about changing the GFX fan to a better one that you can buy from here, just dont really want to buy something like that becuase im probabally going to change the GFX next year for a DX.10 card
