Hi there, as an experiment we are trying to change the background for our users when they login. This works fine but what I notice is that the shadows behind the icons are visible, like so…
it's xp, drop shadows don't make any difference and normal wallpapers work fine, it's only when we use active directory to force the wallpaper change that the problem happens
