Ad Aware 2007 Beta
31 Jan 2007
Hello,
A While ago, I installed the beta version of Lavasofts Ad Aware 2007 beta. Apparantly it has a problem with the install program and It will now not let me uninstall this program. Is there any way which anyone knows of to get rid of the program from the computer and all things associated with it?
Thanks
Neil
Can you not go into Control Panel, Add/Remove Programs and remove it from there? Thats how I remove programs that dont come with an uninstall option.
Are you able to try re-installing it? That may repair any broken registry entries, and allow you to fully remove the program correctly.
I had this problem aswell (but it was not to much of a prob coz my pc needed a format coz there was a lot of junk on it aswell as adware 2007 so thats how i got rid of it)
Manualy remove the files?
Just delete the files from the C:\Program files folder then get a reg tool (regcleaner)and remove all reg enteries in there?
