6 Apr 2009 at 17:57 #1 tres tres Soldato Joined 16 Oct 2007 Posts 7,488 Location UK Can you connect to laptops running XP sp3 together, without the use of a router? ie. wirelessly just between the two? I need to transfer files between them, and going via a weak signalled router is taking ages. Any ideas?
6 Apr 2009 at 18:07 #2 Dano Dano Soldato Joined 19 Dec 2006 Posts 10,400 Location UK Yes, and you correctly called the name too: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
