AD Home Folder Permissions Question
1 Aug 2007
Hi all,
I have a strange issue which has started and I'm not sure why.
I have Home Users share say for example \\fileserver1\users. The users folder security permissions has two groups in there (filersever1\Administrators and fileserver1\Users) and the advanced folder permissions have been changed to Apply To: This folder only.
In the past this has worked fine and always meant a new user created in AD with the Home File path \\filerserver1\users\%username% resulted in a folder with just the user having security permissions.
However...
It now appears that any new users created on \\filerserver1\users also have the filersever1\Administrators group membership with full control. This is despite filersever1\Administrators having Apply To: This folder only set on the users folder.
Any ideas?
There is a group policy setting that adds the administrators group to the profiles.
I'm betting that has been enabled!
Thanks Baz/Lizardking.
Doesn't that only apply to the roaming profile? Not the users private drive? Or does it add the administrators group to the profile and home folder?
