- 2 Feb 2006
- Chepstow, Wales
Just connected my Yuraku 19 inch monitor to my Nvidia 8600GT via a DVI cable and if I select adapter scaling then everything looks a bit blurred but if I select monitor scaling then everything looks ok.
To be honest I cannot see any difference in display quality using the DVI cable or the regular monitor cable.
What difference should there be???
Title should say Adapter and not Adaper........duh.....
Less interference from external sources too.
