Adapter for mini PC-E to PC-E on motherboard?
21 Sep 2003
I posted this in the wrong thread, so giving it a try in here: I got a wifi card which I didn't notice was mini-PCE - but I have a full-sized desktop (Tomahawk Max B450). Are there adapters which will plug into the full PCE slot but have an interface for the mini-PCE to go into?
What WIFI adapter have you got?
A quick search suggests that they are PCI-E x1, so should fit in the small socket on the motherboard.
I have never needed to use a adapter so sorry if this is wrong info.
If it is PCI-E x4 it will work in the bigger slot (will it affect GPU performance?)
