Adapter for Xbox One PSU to use with Xbox E ?
30 Jan 2007
PA, USA (Orig UK)
So I have an Xbox One, and it has the double power plug. I picked up an xbox 360 E for 15 dollars, so I just want to see if it works, but it only has the single round plug. Can you get an adapter for using the Xbox One PSU with the Xbox E ?
I have seen loads of adapters to go from Xbox original (6 pin?) to the slim connector, and from Xbox original to E (single round plug). I just can't see a slim to E or an One to E :(
Any luck?
After some minor research, seems like they are completely different.
I don't want to buy a 40 PSU for a 15 unit lol. I will either try to rig up a PC PSU using an adaptor for original xbox 360 to xbox e, or see if I can borrow a psu to test the system.
