I am hoping this is more of a generic question as opposed to motherboard/bios specific one.
I want my 4770K to lower the voltage when it is not doing much in the similar fashion as it is lowering the multipliers. However I do not want it to go pass the voltage which I have used to achieve my overclocks, because I don't want it to cook the CPU.
So at the moment, I have all the C-states enabled as well as step speed. CPU Fixed mode (multiplier) is disabled so the step speed is lowering and increasing multiplier depending on the load.
But the Vcore is constant in CPUz no matter what the overall CPU frequency is. Currently I have my Vcore set to "Override" or "Manual" and have specified a value for Vcore.
Now I am thinking that it needs to be in "Adaptive" for the CPU to adjust voltage along with multiplier. But the BIOS information says "Additional Voltage" if I choose a value other than "AUTO". I also have a second option for OFFSET Vcore.
so my question is if I want a maximum voltage to be specified in Adaptive mode, do I put this value into the box?
