ADATA PSU's - Arriving tomorrow!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys, we have a new range of PSU's arriving tomorrow. We are exclusive in the UK. They offer great performance and some unique features including a colour changing fan to show at a glance the load going onto the PSU.
Adata HM 1200W Modular Power Supply @ £179.99 inc VAT
Choosing the right power supply affects the lifespan and reliability of your computer. ADATA’s HM Series should be at the top of your list. Certified by 80 Plus Bronze to achieve 82% sustained power, the HM Series provides continuous power in a full range of wattages and includes high-quality 100% Japanese made capacitors. Better yet, the HM Series equips modularized cable management and an intelligent dual ball bearing tri-color LED fan that reduces resonance of the fan axis, resulting in high airflow cooling, and also keeps you informed of your computer’s power status. ADATA HM Series power supplies are the one that delivers you high-efficient performance and ultimate reliability in the market.
ADATA HM Series power supplies deliver superior performance, reliability and protection for all types and levels of applications. In particular, the HM Series equips an intelligent dual ball bearing LED fan with a tri-color output power display for easy access to power consumption stats (green for low load; blue for normal load; red for full load.
ADATA HM Series power supplies feature a smart modularized cable management that allows you to adjust cables according to the number of devices flexibly, reduces unused cable clutter and improves internal airflow for high-efficient heat dissipation within the case. To achieve ultimate gaming performance, the robust 1200W HM Series power supply is not just NVIDIA® SLI®-ready certified, but also supports up to 4 VGA cards. With 12V dual rails, it allows for a "balancing" of the draw so as to guard against being overloaded and, thus, shutting down the power supply unit. In addition, ADATA 1200W HM Series power supply complies with ATX 12V v2.2 and v2.3 and EPS 12V v2.92 for supporting various system configurations, and comes with six 8-pin and four 6-pin PCI-E Express power connectors.
- 3 Colour intelligent dual ball bearing LED fan with a tri-colour output power display for easy access to power consumption stats (Green / Blue / Red)
- Efficiency up to 85% at typical load
- All long-life & low ESR japan made capacitors
- Flexible detachable cable
- Active Power Factor Correction with PF value of 0.9 to ensure reliability and clean power
- OCP,OVP,SCP,OPP,UVP,OTP ready
- PCI-E 6Pin ready for high-end VGA cards
- New circuit for high efficiency & high watt design
- Special Scratch Resistant Paint
- 3 Year Warranty
Only £179.99 inc VAT.
ORDER NOW
Adata HM 850W Modular Power Supply @ £119.99 inc VAT
ADATA HM Series power supplies feature a smart modularized cable management that allows you to adjust cables according to the number of devices flexibly, reduces unused cable clutter and improves internal airflow for high-efficient heat dissipation within the case. To achieve ultimate gaming performance, In addition, it is compliant with ATX 12V v2.2 and v2.3 and EPS 12V v2.92 to support various system configurations and chassis.
- 3 Year Warranty
Only £119.99 inc VAT.
ORDER NOW
Adata HM 750W Modular Power Supply @ £99.98 inc VAT
- 3 Year Warranty
Only £99.98 inc VAT.
ORDER NOW
Adata HM 650W Modular Power Supply @ £92.99 inc VAT
- 3 Year Warranty
Only £92.99 inc VAT.
ORDER NOW
Adata HM 550W Modular Power Supply @ £82.99 inc VAT
- 3 Year Warranty
Only £82.99 inc VAT.
ORDER NOW
Yes 3 Years. Return to OcUK.
This is listed in the full spec tab on the product page (I will add to the forum post/description on the website)
Looks interesting, have a nosey for around for some reveiws :)
Want to change my PC Power & Cooling power supply with something modular.
Adata 650w = £92.99
Corsair 650w = £102.98
Adata 750w = £99.98
Corsair 750w = £99.99
Adata 850w = £119.99
Corsair 850w = £140.99
Adata 1200w = £179.99
Corsair 1000w = £188.93
EDIT :- Damn you for saying the Adata were not cheaper, then editting your post :)
Summary for those who can't be bothered to read the full review:
Final words. I have to say, Adata have done a very good job with the HM 850W, considering that this is their first attempt in producing a power supply that's aimed at the mid-range to high-end market. It's got great build quality, offers rock solid performance and, it can handle all our load tests with very little voltage fluctuations.
Pretty much all you need to know. :D
Adata 650w = £92.99
Adata 750w = £99.98
lol :D seems I underestimated Corsair's pricing
Corsair = 7 Years Warranty
Adata = 3 Years Warranty
I think it's safe to assume the extra money is worth it. ;)
Seems ok but nothing special. Surprised they are not 80 plus gold or silver considering they have just been released. Similar priced psus tend to come with a 5 year warranty too. (e.g. corsair 750W vs adata, both £100).
Priced to near corsair for my liking, only three year warranty opposed to corsair seven year and I know corsair RMA is top notch, I know nothing of Adata.
Adata 1200w = £179.99 - Looks very interesting !! hmmm... never had ADATA of anysort before. I hear there RAM's pretty good.
Fair comments guys but typically if a PSU dies it within the first few months.
I'm just giving people options.
The best product in the line up is the 1200w PSU.
