- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys, we have a new range of PSU's arriving tomorrow. We are exclusive in the UK. They offer great performance and some unique features including a colour changing fan to show at a glance the load going onto the PSU.
Adata HM 1200W Modular Power Supply @ £179.99 inc VAT
Choosing the right power supply affects the lifespan and reliability of your computer. ADATA’s HM Series should be at the top of your list. Certified by 80 Plus Bronze to achieve 82% sustained power, the HM Series provides continuous power in a full range of wattages and includes high-quality 100% Japanese made capacitors. Better yet, the HM Series equips modularized cable management and an intelligent dual ball bearing tri-color LED fan that reduces resonance of the fan axis, resulting in high airflow cooling, and also keeps you informed of your computer’s power status. ADATA HM Series power supplies are the one that delivers you high-efficient performance and ultimate reliability in the market.
ADATA HM Series power supplies deliver superior performance, reliability and protection for all types and levels of applications. In particular, the HM Series equips an intelligent dual ball bearing LED fan with a tri-color output power display for easy access to power consumption stats (green for low load; blue for normal load; red for full load.
ADATA HM Series power supplies feature a smart modularized cable management that allows you to adjust cables according to the number of devices flexibly, reduces unused cable clutter and improves internal airflow for high-efficient heat dissipation within the case. To achieve ultimate gaming performance, the robust 1200W HM Series power supply is not just NVIDIA® SLI®-ready certified, but also supports up to 4 VGA cards. With 12V dual rails, it allows for a "balancing" of the draw so as to guard against being overloaded and, thus, shutting down the power supply unit. In addition, ADATA 1200W HM Series power supply complies with ATX 12V v2.2 and v2.3 and EPS 12V v2.92 for supporting various system configurations, and comes with six 8-pin and four 6-pin PCI-E Express power connectors.
- 3 Colour intelligent dual ball bearing LED fan with a tri-colour output power display for easy access to power consumption stats (Green / Blue / Red)
- Efficiency up to 85% at typical load
- All long-life & low ESR japan made capacitors
- Flexible detachable cable
- Active Power Factor Correction with PF value of 0.9 to ensure reliability and clean power
- OCP,OVP,SCP,OPP,UVP,OTP ready
- PCI-E 6Pin ready for high-end VGA cards
- New circuit for high efficiency & high watt design
- Special Scratch Resistant Paint
Only £179.99 inc VAT.
ORDER NOW
Adata HM 850W Modular Power Supply @ £119.99 inc VAT
ADATA HM Series power supplies feature a smart modularized cable management that allows you to adjust cables according to the number of devices flexibly, reduces unused cable clutter and improves internal airflow for high-efficient heat dissipation within the case. To achieve ultimate gaming performance, In addition, it is compliant with ATX 12V v2.2 and v2.3 and EPS 12V v2.92 to support various system configurations and chassis.
Only £119.99 inc VAT.
ORDER NOW
Adata HM 750W Modular Power Supply @ £99.98 inc VAT
Only £99.98 inc VAT.
ORDER NOW
Adata HM 650W Modular Power Supply @ £92.99 inc VAT
Only £92.99 inc VAT.
ORDER NOW
Adata HM 550W Modular Power Supply @ £82.99 inc VAT
Only £82.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
