Adata S510 120GB with Acronis True Image for.... see inside ;)
20 Jul 2009
The bleak North East arm pit of Britain
Hello
Hows this for a spanking deal! :D
Adata S510 120GB SATA 6Gb/s Solid State Drive - Retail with Acronis True Image @ £64.99 inc VAT
The S510 is a highly cost-effective option for SSD upgrades of existing systems, and for new SATA 6Gb/s enabled computers. The S510 utilizes the new generation SandForce SF-2200 series controller, with native support for the SATA 6Gb/s platform. In both desktop and notebook computers, users will enjoy an unprecedented high-speed experience. The S510 can reach 550/510MB read and write speeds respectively, with 4K random write speeds as high as 85,000 IOPS.
Superior to Mechanical Drives on all Fronts
Solid state drives require no defragmentation, and support the Windows TRIM command. The S510 provides vibration-free running and low power consumption, while taking full advantage of the 6Gb bandwidth transmission capability.
What is the Windows TRIM command optimizing component?
If your computer is running the Windows 7 operating system, the Windows TRIM optimization command can directly delete stored data in the Flash memory and release unused space (Free Blocks) to be used for system writes immediately. This results in more accelerated transfer and write performance for solid state drives, and is also effective in slowing down efficiency decline and depletion chances, maintaining effective operation and extending the life of the disk.
Powerful and Free Software Solution to Eliminate Reinstalls
All purchasers of the S510 can download the free Disk Migration Utility software. It facilitates the quick transfer of all files to the new solid state drive, significantly reducing the troublesome and time-consuming process of reinstalling software and restoring data from backups.
* Disk Migration Utility software runs on these operating systems: Windows XP / Windows Vista / Windows 7
Software Download Area: http://www.adata-group.com/index.php?action=ss_main&page=ss_software_5
- Capcity: 120GB
- Read: Up to 550MB/S
- Write: Up to 510MB/S
- Seq Read: Up to 200MB/S
- Seq Write: Up to 140MB/S
- 4K Random Write (Aligned): 60,000 IOPS
- Maximum 4K Randdom Write: 85,000 IOPS
- Sandforce SF-2281
Included in the box
- SSD 2.5" to 3.5" adaptor in metalic blue
- Mounting screws
- Code to download Acronis True Image
Was £86.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
As you can see, this is essentially an V+200 or an Force 3 but with Acronis and much cheapness too!
3 left in stock, hundreds landing on Tuesday!!
:D
I guess it depends how much manufacturers want to shift over supply, but a decent SATAIII for around £100 ish would be a winner.
