- 16 May 2006
I'm mulling over an upgrade in time for BC3
I'm wondering which way to go; I'm going to pull out the old faithful q6600 and get an i5 2500k with 6gb so that should be taken care of cpu/ram side, but the gfx option is stumping me. Do I grab another gtx 280 for sli or go with a new single card solution? You can pick up the 280s cheap enough these days, but it would involve a power supply upgrade (recommendations welcomed!) so the savings could quickly be lost compared to singe card solution.
Advice would be welcomed!
I'm wondering which way to go; I'm going to pull out the old faithful q6600 and get an i5 2500k with 6gb so that should be taken care of cpu/ram side, but the gfx option is stumping me. Do I grab another gtx 280 for sli or go with a new single card solution? You can pick up the 280s cheap enough these days, but it would involve a power supply upgrade (recommendations welcomed!) so the savings could quickly be lost compared to singe card solution. Advice would be welcomed!
