Add more USB C ports to MacBook Air - Recommendations?
Consigliere
12 Jun 2004
SW17
Hey all,
Weirdly I am having issues finding a USB C Hub to connect to my MacBook Air as I need to connect 4 devices in total (so 2 extra than what I have at the moment).
I can only seem to find ones that have other types of connectors plus maybe 1 or 2 USB Cs.
Any ideas?
If you want only USB-c usually prices go up quite considerably. Startech has one but should be in the £75 region. Sitecom CN-385 (or 386 for powered version) is about £40-50 and has only 3 ports. There are some 3-4 port ones from unknown brands on various websites as well that go for £30 but I can't comment on the quality.
