My gaming PC is connected to the main house router via a (40 meter) lan cable,
I have one of those wifi boosters that work over the power lines with the 2 mains plugs... one at the router end, and the other in the room the laptop is in, and use that to connect the laptop to the home network and thus internet.
I want a seperate private wifi network that is not connected to the internet, and does not involve all the hops back to the home router and that....
this is to connect 4 x android tablets plus my phone (and later some controls) over wifi to the gaming pc, where i run a little program that extracts data from the game (TS2019) and sends it via wifi to the tablets, they then display this data mimicking the displays in the game... giving me a total immersion control desk of a train basically.
So, i want a wifi card i can put in the PC, that i can set up so it does not connect to the internet, but works as a private wifi hub so to speak, where i can connect the tablets to it, and they will only see the private network... no internet.. so no bloomin updates every 5 minutes for apps i never use.
How can i do this? can i even do this using a PCIe wifi card? or do i need a usb wifi router?
as you can tell, i am a noob at this wifi set up stuff.... i'll need telling what to change and where to set this up.
The software on the PC, i just set the network address i want to use, i.e. 192.168.1.2, and port: 47812, and do the same on the tablets,
Then start the server program on the PC then the game, and start the apps on the tablets, and they talk to eachother over the wifi... only ATM with lots of annoying lag which causes the flasthing lights to go out of sync with the ones in the game.
