Add Speed camera option into old Tomtom?
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
My dad has a Tomtom go 500, and wants to add speed camera database into it, how does one do that? Flash the software? SD card ?
Get the latest Speedcamera database from pocketgps world and simply copy the files to the folder where the map is located.
You then go into the POI (Points of Interest) section of the options menu and simply enable the speed camera warnings you want to be displayed.
You will have to manually set the warning distance for each warning. Heres a nice table:
Mph - 30s - 20s - 15s – 10 secs warning.
70 - 1173- 782 - 587 - 391 yards
60 - 1026- 684 - 513 - 342
50 - 879 - 586 - 440 - 293
40 - 732 - 488 - 366 - 244
30 - 588 - 392 - 294 - 196
20 - 441 - 294 - 221 - 147
