add wireless to ethernet connection...?
16 May 2005
hi
freind lives in a caravan in folks garden. he's run an ethernet cable out there, but is looking to use wireless.
could i please have a suggestion for a cheap gismo that will allow wireless connection to the existing cable? speed not really too much of an issue, its just for browsing etc.
many thanks
nobby
Wireless access point.
If he buys a 'PoE access point', he can use a PoE injector on the house side and then the access point will be powered by the ethernet cable, meaning he won't need to use up a plug socket for it in the caravan.
or a normal wireless access point.
https://www.overclockers.co.uk/asus...nder-access-point-media-bridge-nw-089-as.html
This type, plugs into a power socket and the ethernet goes into the bottom of it.
You'll need some very basic networking knowledge to set it up.
It shouldn't be.
There are loads of guides available. Google 'router as access point' or something similar.
The process has been detailed on this forum many times as well.
A quick guide...
  1. Find out the subnet (e.g. 192.168.0.n) the rest of the network is using.
  2. Find out the limits of the network's DHCP range.
  3. Connect a PC to the router to be configured. Don't connect the router to anything else at this stage.
  4. Configure the router so it's using the same subnet as in step 1.
  5. Set the router's management (gateway) IP to something that doesn't clash with the DHCP range from step 2.
  6. Configure the wireless settings you want to use.
  7. Disable the router's DHCP server.
  8. Connect the router to the end of the Ethernet cable using one of the LAN ports. If it has an Ethernet WAN port ignore it.
  9. If all is well (and I haven't forgotten a step) it'll be working and will be accessible on the IP set in step 5 for admin.
If you're lucky the router may have an AP mode that does most of the above for you. It's worth checking.
It's easier to do than it is to describe.
An other option for wireless + Ethernet is to connect a small network switch on to the end of the cable and then plug an access point into that.
You can use an old consumer broadband WiFi router as an access point if there is one knocking about
Assign it an IP address, turn off dhcp, etc setup WiFi with the same details as what I would assume is WiFi setup in the house, secure the device and turn off any features you don't need to use
Or buy an access point
that sounds more of an arse than telling him its wireless only :D
Setting up a normal wireless access point involves pretty much exactly the same steps. Minus the 'disable DHCP' section.
As said above, you'll need some basic networking knowledge to set one up.
