Added 2 gpu, now motherboard having issues
22 Oct 2012
The Moon
I'm using a z87xoc motherboard and it was all working, until today when i added a 2nd gtx 970.
The board starts with an error code 19 then instantly moves to 15, and just endless reboots without posting an image on the screen.
Any ideas?
Thanks.
Ok, I really don't understand this at all.
Booted with only 1 stick in both slots 1 and 3, works fine.. used the other ram in slot 3 works perfect, fails in slot 1, then move to 3 and fails again.
Reboot, try in slot 3 then posts
Trying both sticks fails too.
slots 1 and 3 for better airflow.
[/URL][/IMG]
1 and 3 are correct as SLI will only work in those two slots.
Memory wise, the two orange slots are the ones to populate
You could "try" connecting the PEG OC 6 pin power connector. Just above your first GPU.
