- 9 Dec 2009
- Bristol
Hi all
I have several 900x600 stone slabs in Kandla grey, which I'm going to use to replace the hydraulic slabs which form our garden path, and I'm then going to build a doorstep upon 1 course of bricks topped with one slab.
The slabs have hand hewn edges, and though they do look rustic, this might cause a trip hazard for the step, so I'm looking at whether it's feasible to add a bullnose edge to the outer facing 3 sides
Has anyone done this?
Here's the 2 options I'm looking at:
Use a 4 inch grinder with grinding/sanding pads (rather than a cutting wheel) and grand back the squared edge to a 45 degree bevel, then take the edges off that and gradually round it off. Then turn the thing over and do the other side.
Or, buy one of these supposed diamond bullnose grinding wheels from eBay/Amazon and use it to grind the bullnose shape.
Or I could use a mixture of both methods. I appreciate that this might take some time to achieve a good result, but seeing as I'll pass it several times every day I want to make a good job of it otherwise I'll be annoyed!
Any advice welcome, thanks.
10-30mm Round Dry Vacuum Brazed-Diamond Grinding Wheel Demi Bullnose Edge New | eBay UK
Grinding on marble, granite, quartz, ceramics, artificial stone and glass. -- 1 Grinding Wheel. -- Can be used dry or wet. -- Applicable machine: Angle grinder. Sound & Vision. -- Especially for concrete outside wall in building or decoration.
www.ebay.co.uk
