Adding a copper shroud to an old PCI sound card
26 Sep 2010
Stoke-on-Trent
Hey there. This is technically a modding question but I thought it probably best asked here given you're all likely to be audiophiles and much more knowledgable than me.
So, the deal is I'm in the planning stages of an extensive aesthetic mod of my old socket 478 P4 workhorse to bring in modern design cues like motherboard armour, I/O shrouds, GPU backplates, etc, and I want to extend that to my old Sound Blaster Audigy.
The theme so far will involve 0.9mm thick copper sheet in places, but I have no idea if wrapping some of this around the sound card is going to cause interference. Obviously the copper isn't going to be in contact with any components, just a bit of a sleeve over the top.
Thoughts, tips, etc. appreciated.
Cheers!
Sweet, cheers guys. I'll be 3D printing a skeleton for the shroud and then laying the copper sheet over the top, with an acrylic sheet over the top of that for some entirely unnecessary lit etching effects :p
You need to do it in a way your 3D printed shell is grounded without the copper touching the PCB. Via the grounded screws.
Have a look at how other sound cards has them mounted.
Ah gotcha, brain fart moment. Good to know for when I get some proper design work down.
Cheers!
It was just some initial asking around. I'm doing tentative designs and planning for my 2nd mod project, but I don't have the space to do anything substantial (i.e. get the hardware out :p ) until the 1st project is finished.
Also, the use of actual copper is dependant on me getting a nice brushed finish on the metal, if I can't manage it then there's likely to be paint involved instead :P
It will happen though, just likely not towards the end of the year as Asteria II is a major time sink :(
