YOUR BASKET
[*] 1 x intel core i5-3570k 3.40ghz (ivybridge) socket lga1155 processor (77w) - oem £187.99
[*] 1 x Zotac GeForce GTX 1080 AMP Edition 8192MB GDDR5X PCI-Express Graphics Card (ZT-P10800C-10P)= £619.99
[*] 1 x gigabyte z77-d3h intel z77 (socket 1155) ddr3 motherboard £89.99
[*] 2 x avexir core blue series 8gb (2x4gb) ddr3 pc3-12800c9 1600mhz dual channel memory kit (avd3u16000904g-2cw) - blue light £37.99
[*] 1 x Corsair Obsidian 450D High Airflow Mid-Tower Case (CC-9011049-WW)= £106.99
[*] 1 x Corsair CS650M 650W Semi-Modular 80+ GOLD Certified Power Supply (CP-9020077-UK)= £84.95
[*] 1 x thermalright macho 120 cpu cooler (socket 775 / 1155 / 1156 / 1366 / 2011 / am2 / am2+ / am3 / fm1 / fm2) £29.99
[*] 1 x Crucial BX200 240GB SSD SATA 6Gbps Solid State Drive (CT240BX200SSD1)= £65.99
[*] 1 x WD Blue 2TB 5400rpm SATA 6Gb/s 64MB Cache HDD - OEM (WD20EZRZ)= £70.99
[*] 1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM= £17.99
[*] 1 x Corsair SP140 Twin Pack Blue LED Fans (CO-9050036-WW)= £24.95
[*] 1 x AOC AGON AG271QG 27" 2560 x 1440 IPS G-Sync 165Hz Gaming Widescreen LED Monitor - Black/Red= £599.99
Hi guys, I've made some recent upgrades which I'm extremely happy with, however, my system is a bit loud.
The fans seem to be constantly on max.
I have 5 case fans in total: 2x 140mm LED corsair at top, 2x 140mm corsair fans in the front (came with case)and a zalman 120mm.
Was looking to get a fan controller, to control the case fans and maybe turn them down to lower the noise levels.
Was wondering if this would work:
[*] 1 x NZXT Sentry Mix 2 Fan Controller - Black= £29.99
It says it dishes out 30W per channel... 180W in total. Is that a constant output? Would my PSU cope with this addition?
