adding a gpu block to my loop question
22 Oct 2010
Pontefract
adding a gpu block to my loop, what would be best?
option 1 would use a Y splitter to add extras into the loop
BIG 250mm tube res -Pump - Y splitter
then from the splitter
line 1: 120mm rad - CPU block - res
line 2: 120mm rad - GPU block - res
option 2 just add the extras in after a first loop
res - 120mm rad - cpu block - 120mm rad - gpu block - res
Witxch would be the best option. or should i just get an extra pump and run 2 loops
you could have one loop on the gpu and one on the cpu different colors in each always looks nice
id have headertank > pump > cpu > gpu > rad
in series
ur header can be a full size res or just a small header and pop another res in the loop somewhere else also if you want more volume.
thats just the way i like to do things as i like lots of volume
so mine is (without cpu cooler thats next) external small pump header tank > pump > internal cpu> internal res > external rad > res > back to small pump header again
so in effect i have 3 resevoirs small one as a header and a big one outside and a big one inside
my little ass pump runs it all fine on half inch tubing ek2.2 no problems with it at all the water flys around and is nice and turbullent in the top res which is the only one i keep an air gap in
