Hey guys,
I have a question regarding a system that serves a rendering purpose for 3D work in Cinema 4D + Octane Render. I currently have an RTX 2080 and would like to add an RTX 2080ti (I heard that adding the same type of card is the safest option. Personally, I'm a complete amateur with the hardware, so I'm planning to order the graphics card and get someone to install it for me.
All I wanted to do is run a check with you, more experienced guys - is installing an additional card completely safe and won't overload/overheat the PC? When I was ordering it, I asked for some space for future upgrades. Will the ti version work with the regular one fine? Which version of that card would be the best one to order and why?
I'm attaching some of my specs, let me know if any more information would be needed:
NVIDIA GeForce RTX 2080 8GB GDDR6 Graphics Card
Processor: Intel Core i9-9900K CPU @ 3.60GHz 3.60 GHz
Ram: 32 GB
Noctua NH-U14S CPU Cooler
Gigabyte Z390 AORUS PRO Motherboard
Thanks for your time
Antek
Ram: 32 GB
Antek
