So I'm planning on adding a Mesh network to my Sky Q router.
From my understanding the simplest way to do this would be to put the new Mesh nework (eg: Orbi or Velop) into bridge mode, so the Sky Q router is still the "boss"?
BUT, in doing this you typically then lose loads of the features of the Mesh network such as device monitoring and the like.
So, to get over this, I'm trying to understand the hurdles of setting it up so the Mesh isn't compromised by having to run in bridge mode? It seems to involve?:-
1) Set the Mesh hard to a dedicated/fixed IP.
2) Set up a DMZ (what ever that is) on the Sqy Q rotuer to that IP. I assume that tells it to pass control over to the Mesh hardware?
3) From then on all port forwarding and the like (I do for game servers etc) would have to be defined on the Mesh hardware, not the SQy Q router as now?
4) All devices (ethernet cables) would be plugged into my Mesh hardware, and none into my Router (except the single lead from the router to the Mesh)?
With the above could I retain the Sky Wifi albeit even on a different name? Because I believe it's very fussy about using its own network if you use any of the remote sky Hubs for TV viewing?
Is anyone able to help explain if there's a better option? Or if the above is the best way, and will indeed work?
