Nope, for decreasing number of cables they have only wireless ModMic.Interesting. Is there a Modmic that incorporates the headphone and microphone cable into one cable, like the Boompro does?
you forgot to add the cost of mod mic itself lolI used the Modmic USB and it works really well.
£1's worth of micro velcro easily solves the two cable problem.
Vmoda BoomPro here with the adapter. Works perfectly, no cable mess and adapter is tiny so not much distance added.
Adapter
I did think that too, but pretty sure i found a picture of the other end and its not 3.5mm female.Looks like they have shortened one of these:
REAN RT3FCB 3 Pin Mini XLR Female Plug Ta3f Wireless Microphone Guitar Connector
They probably made it shorter and adapted it to 3.5mm. The place that sold them did say they were custom made and I couldnt find them anywhere else
During summers I prefer like 1cm hair length (actually ½cm is good for fast drying) and never had problems with that particular thing.FYI, 702s are so much comfier after adding some head support...
I'm actually shocked AKG did not think of this or even bother to test the headphone on people with no hair. Without support, a pressure point is created in one place with makes them unusable after 10 minutes (for me anyway)
