Adding a second HD
8 Jan 2009
Northern Ireland
Im trying to add a second HD, and when I reboot Im getting a message, BOOTMGR IS MISSING, PRESS CTRL+ALT+DEL TO RESTART. Anybody know of a way round this. Thanks
You will need to go into your BIOS and change the boot order, so that it looks for your original (OS) drive first.
There will usually be a message to hit DEL or an F key as the machine first starts, which will let you go in and change the settings.
In the BIOS my 500GB drive is boot, where the 320GB drive is second. But in Computer management my 320GB drive shows up as Disk 0, and my 500GB, shows up as Disk 1, if I swop the data cables about, I get the BOOTMGR is Missing.
