In short yes. You just need to use an mcb that is rated appropriately. That would be 15A or 16A. You then run a 2.4mm2 cable from the fuse box to the junction box that then connects to the armoured cable. The other end of the armored cable, in the garage or whatever, goes right to your socket. A 2.5mm2 lead from that socket goes to a fused switch, with a 3~6A fuse, which then uses 1.5mm2 cable to connect to your light(s). It's pretty common to use 20mm conduit to cover the lead that goes from the socket to the fused light switch and they are usually placed close so not much conduit is involved.
All of this is fine as long as the lengths are not ridiculous, in which case you need to take in to account voltage drops and so on, so, you know, keep the cable runs within reason.
