Adding a temp sensor
17 Nov 2011
Birmingham
Hello i was planning on adding a temp sensor to the bottom of my ek bridge, and was wondering if would work at all. Here is my setup:
My loop flows upwards from bottom gpu so iwas hoping to place the sensor at the left hole if that seems possible
That would be fine. I'd stick it in the right hole so you know what temp the coolant is going into your GPUs.
That will be fine,i would just remove the extender completely tho as it would look a little out of place imo.
It was leaking last time i tried directly into the bridge and im sure i read somewhere you need an extender
few days later and the things melted the cables :\. Had a quick google and it seems its a common problem
The xspc temperature sensor that is
