Adding a Wireless Extender to VM Superhub
9 Aug 2004
Plymouth, UK
I currently have a VM Superhub in the loft (typical 2 storey semi-detached house) - Superhub is sitting right above the loft access hatch, roughly in centre of the house footprint.
I am getting patchy wifi signal in a couple of rooms on the ground floor - will the attached help boost signal if I mount it on 1st floor, almost directly beneath the Superhub?
http://www.overclockers.co.uk/showproduct.php?prodid=NW-204-NG&groupid=46&catid=1837&subcat=
I assume that it is easy to set up.
Cheers
powerline work well, and have used a few wireless repeaters and access points with VM hubs, cant say i've had a problem with any make so far, bought cheap ones and branded ones as well, all worked fine for me..
Thanks for feedback...the more I read about the VM Superhub the more I am minded to bite the bullet, set it to modem only mode and buy a new £100 wireless router (Asus N66U with better wifi capability).
