I currently have a RayStorm D5 RX240 WaterCooling Kit loop set up and going to get a 680 xspc razor water block to add to it.
I have the rad on the back of my case as Its a coolermaster trooper as Its to much of a tight fit for the rad it inside.
I dont have a clue how I will even route the tubing with adding a gfx card to it?
I could do with a diagram of sorts just to get an idea how it will look..thanks
