ADDING AIR FILTERS TO 900D
7 Jan 2010
Up NORTH
Hi all,
Anyone going to be doing this with this case as there is a lot of vents THAT
could pose a threat from dust especially at the rear of the case?
Cheers
Thinking of the 900d, If you set the case up with a pressure optimized fan setup you should be in taking more air from the top and front and sides than is being exhausted out the back. Which means all the in takes will be filtered and there will be lest dust coming in from the back as it will be pushing air + dust out.
So shouldn't be too much of a problem, you can get dust filters for the rear fan however that just sit between the fan and the case.
I do know DEMCiflex do entire case fan filters but then are on the pricey side not sure if they have done one for the 900d though.
Cheers for that. Pressure optimised fan setup? SORRY I'm a total noob when it comes to that lol
I have 3 pwm corsair on front intake at about 600rpm
2 connected to h100i pulling 900rpm out of top and 1x140mm at rear at 600rpm
Is that any good? As my cpu sits at around 26/30c
