Adding an argu,ment in task scheduler
14 Jan 2010
Essex
My rear fans seem to only run properly once MSI command center is loaded, but every time the computer restarts the rear fans stop again and will only load, once you apply a certain action in command center. (they are connected through a splitter and I think that's the main problem)
So im setting up task scheduler to start the program every time logged on, but Im hoping to add an argument that presses the button i need once the program is open (if possible)
if not possible, i am open to suggestions. Speedfan doesn't recognise any of the software or fans so that's a no go.
TIA
