Adding Avi to Itunes
3 Dec 2002
Groovin' @ the disco
Hi
How do a add an avi file to itunes library? I tried importing and add to library - but nothing happends. the files are divx files and I need them in itunes to play them in front row.
Thank
you don't need to add them, you cannot add them anyway
put them in the movies folder and they will show up in frontrow and will be playable
Or you can create a shortcut in your movies folder to the folder where you store them, saves creating copies.
FYI: If you don't have the right codec it will just show a blank screen in FrontRow.
Try downloading VLC player if you don't use FrontRow, or failing that if you need to use the FrontRow goodness download the DivX codecs
Thanks for the tip, I was just about to ask why I get a black screen with avi files.
I knew I felt a disturbance in the force ;)
