adding different sizes of dual channel kits
20 Oct 2014
Hi just a quick question I have trident x ram 2x8gb kit can I add the exact same memory but a 2x4gb kit so I would have 24gb in total without taking any sort of hit with speeds etc ?
cheers all
Nope.
Very occasionally you won't be able to overclock as well with 4 DIMMs as with 2, but even if you had to drop the clocks slightly you would never notice the difference.
My RAM for example, 4x8GB, is supposed to be 2400mhz. I can run at that with any two DIMMs.
With 4 DIMMs, there is more load on the memory controller, and it's only stable at 2133mhz.
So, as I said before, you may have to de-clock the RAM slightly, but it will work.
