Hi,
Just got my H50 this morning. It comes with a 120mm fan to blow air across the radiator. The radiator has threaded screw holes on both sides. It only come with 4 screws but the whole unit is not really that heavy. I was thinking if it would be worth using just 2 of the scews to mount it to the case and the other 2 to mount an aditional 120mm fan on the other side. Obviously blowing air in the same direction.
Or would I gain anything by doing away with the fan included and using 1 or 2 Noctua NF-P12's instead?
