Adding fans to 750d for better airflow
Caporegime
18 Oct 2002
Ireland
Any fans in particular that are quiet and can pull a lot of air through a case? Not really all that sold on the 140's the case comes with for some reason.
I'd normally scream "NOCTUA FANS" at this point... but while they're nice and quiet, the performance is slightly lower than average. It's a fantastic balance if you want silence, but they're not the top...
Enermax T.B.VEGAS DUO UCTVD14A
15db @1500rpm
Only delivers 1.8mm/H2O) of static pressure, but shifts a whopping 154m³/h (that's 91CFM) of airflow!!
Noctua NF-A14 PWM
25db @1500rpm
2mm/H2O, with 140m³/h (82.5CFM).
Both are 140mm fans and both cost about £20.
I would try some SP120's? The SP should be better at the front as the front isn't mesh and is quite restrictive, so it's better to get some static pressure fans
Was actually considering modifying the front panel with a cut out, would be a pain to do and keep it looking good though.
