Adding insulation to flat roof
28 Dec 2017
Beds
The house we've bought has a flat roof (mid 60s built) and I've finally had time to investigate a bit. We're hoping to add any insulation that's possible - depending on how cold it gets this winter it might be a priority, or might just be common sense as we're renewing ceiling boards.
The roof was replaced 2 years ago (with bitumen felt), not much info on the invoice but it does mention adding insulation. From what I can tell it's a warm roof construction - it looks much like the ceilings between floors i.e. plasterboard then cavity with wooden joists. Above this is some kind of fibre insulation, but it's formed into blocks/sheets and is rock hard? Never seen this stuff before.
So the question is, can I put either rockwool or celotex/PIR board into the gaps between joists? If I can, do I need to leave a gap above/below? FWIW it felt reasonably draught free and dry up there but didn't exactly spend a long time taking readings. Don't want to add insulation and cause condensation or air flow issues.
There's a full 17cm of joist height so could easily get 100mm board in there if permitted and still leave an air gap. Ceilings are only 235cm high so rather not lose any height with adding insulation board below the joists, but if it helps...
Give this a read, figure out which yours is and see if there is space to add more insulation while maintaining ventilation.
looks like stramit board
you could remove cieling ,install fibreglas/rockwool/or similar (maybe kingspan)and reboard and skim
Well this is the question, it looks and feels to be a warm roof but I can't see beyond the blocks on top of the joists. My gut feeling is warm roof and no ventilation needed but would prefer some reassurance. For example are the fibrous blocks I'm seeing, part of a secondary insulation? Or no vapour barrier and boarding between joists and insulation?
Thanks, definitely looks like stramit board now I've had a Google for that name! So if I add some insulation should I butt it against the stramit and leave a gap before plasterboard, or aim to have a gap between new insulation and that stuff?
Would it take a living roof on top?
I wouldn't like to trust it given it's a pretty cheaply built house, and council probably won't want me adding it on 40m² of roof...
TBH I don't know m8.i would maybe fill the gap with rockwool .hopefully someone who knows will pop in here and verify which is best
