hi all,
I'll try to explain my problem.
First off, specs that may help:
mobo asus A8N SLI Deluxe,cpu opteron 170,memory 2x 1gb crucial ballistix DDR pc3200, 2x 1gb OCZ DDR pc3200, suond x fi elite pro, gfx nvidia 9800gt, os windows7 rc1/windows xp pro.
Now, to try and explain.I have been running my system using 2gb ballistix memory on both xp and win 7beta with no sound problems. swapped to win7 rc1 and all still seemed ok. I decided to add an extra 2gb of memory but couldn't get any matching ballistix memory so opted for OCZ (Was told should be ok but would run at whichever had the lowest settings).When all 4 sticks of memory are in, my sound is so bad its unuseable, but only in win7. If I boot to xp no problem. If only install either ballistix or OCZ sound fault is gone.
Are these two type of memory incompatible or is it just timings that may need setting up(not too clued up on mem settings)? or is it just a win 7 problem as xp seems fine(saying that though,xp only recognises 3gb of memory) sorry to be so long winded but any help would be appreciated.
