Adding Molex, SATA Power, IDE and SATA Ports...
19 Jan 2003
Bristol, UK
It would help me a lot with my work if I was able to mod my case to accomodate a set of the external ports mentioned in the title.
I have all the spare ports on my mobo so basically just need some sort of male to female cables and a way to either mount them in the rear of the case, side or front.
If anybody has done anything along these lines then please advise, post pics etc...
EDIT - Another idea I like is a custom made break-out box I can put on the desk with these connectors on...
Many thanks,
Chris
You can buy an external port PCI adapter from a competitor.
Can't say much more mind. :)
Molex, Sata, 3pin fan connector and if you use adapters for the sata power it would be good. :)
