Hi guys.
I purchased this system from OCUK a while ago:
It's been running very well since I bought it but recently I've found my system using a hell of a lot of memory sometimes. It will go to 90%+ physical memory usage and will cause the game I'm playing to slightly stutter sometimes which is really annoying.
I'm not sure what's causing that problem - I can't put my finger on it even after staring at resource monitor whilst it happens, svchost seems to be hogging a lot of ram sometimes. I've been in msconfig and disabled a bunch of services/start up programs but no luck so far.
I'm sure a reformat would sort me out but I can't be bothered to be honest & I really don't have the time to try work out what's causing the increased memory usage.
What I'd like to do is put some more RAM in my machine. However when I bought my pre overclocked system from OCUK I remember it said in the description that adding more RAM to the system may cause the overclock to become unstable.
I'd like to add another 4gb memory (2x2gb kit) into the machine, so I'd have a 2gb stick in each slot with a total of 8gb.
I'd buy the exact same memory that is already in the system.
Would this be a problem ? If so - what problems would I face doing this ?
Is it a simple case of changing a few values in the bios for the new sticks of RAM or would I actually have to change all the overclock settings done by OCUK and end up having to use a lower overclock than I currently am using ?
Forgive me if I've asked stupid questions - I have zero experience overclocking CPU/RAM the only overclocking I have ever done was on my new graphics card today which just involved moving two sliders in CCC !
Would appreciate any help/advice given, I want to make sure I wont be making a mistake purchasing more RAM for my system.
Thank you.
"Radon Torosaur" Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle
Mainboard : Gigabyte P67A-UD4-B3
Processor : Intel Core i5 2500K
Physical Memory : 4096MB (2 x 2048 DDR3-SDRAM ) (CMX4GX3M2A1600C9)
Operating System : Windows 7 Home Premium Home Edition Media Center 6.01.7600 (64-bit)
Thank you.
