hi i noticed my pc gets quite warm currently i have 2 intake fans and 1 exhaust, my case fans at the moment cant be controlled and their max speed is quite slow, my case has space for two more exhaust fans on the top how do i connect them? my set up is 1 default low rpm fan at the back and which is built into the case, in the front i have my cpu watercooler fans - H100iv2, whilst these are good for short term gaming 2/3 hours i notice where the motherboard and gpu connect (center of the case) heat builds up so i was planning on adding two more high power fans to the top of my case, i will also probably swap the awful low rpm fan as i dont think its remove hot air quick enough
i am planning on getting this "Corsair CO-9050039-WW ML Series ML120 120 mm Low Noise High Pressure Premium Magnetic Levitation Fan" as it says it has strong fans to cool my pc, and i need some strong fans to move the hot air from my cpu - these fans are 2400rpm which im guessing by having two of them as an exhaust should move the hot air pretty well?
my motherboard has 8x 4 pin but im not sure what that is or how many are not being used
i have never built or modified a pc before just a heads up, is it simply screw to the case and connect the one wire and boom it works?
current specs
CP-62F-IN Intel Core i7-7700K 4.2GHz (Kaby Lake) Socket LGA1151
Processor - Retail
HS-038-CS Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU
Cooler (CW-9060025-WW)
HD-36K-SE Seagate BarraCuda 2TB 7200RPM SATA 6Gb/s 64MB Cache HDD -
OEM (ST2000DM006)
CD-003-OK OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
SW-172-MS Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
XX-003-OP Standard Build Systems - Dispatched within 7 working days
MB-54L-GI Gigabyte Aorus GA-Z270X-Gaming 7 Intel Z270 (Socket 1151)
DDR4 ATX Motherboard
MY-464-CS Corsair Vengeance LPX 64GB (4x16GB) DDR4 PC4-21300C16
2666MHz Dual/Quad Channel Kit - Black (CMK64GX
CA-021-KK Kolink Vault Midi Tower Gaming Case - Black/Green LED
HD-105-KS Kingston A400 120GB SATA 6Gbs 2.5" Solid State Hard Drive -
(SA400S37120G)
GX-001-AU Gigabyte Aorus GeForce GTX 1080Ti "Xtreme Edition" 11264MB
GDDR5X PCI-Express Graphics Card
CA-182-CS Corsair HX850i 850W '80 Plus Platinum Digital Modular Power
Supply (CP-9020073-UK)
NW-100-TP TP-Link Gigabit PCI Express Network Adapter (TG-3468)
current specs
Processor - Retail
OEM (ST2000DM006)
(SA400S37120G)
