Adding php in dreamweaver and to test offline
12 Jun 2012
West Yorkshire
Hi guys.
Im struggling on the best way to ask this.
I am wanting to try and add this plugin into dreamweaver just to test the functionality if its something i could use.
The install instructions are to install it onto a webserver although i do not have access to one yet. What is the best way to install this to get it up and running offline?
I am using dreamweaver to make this site?
Note: I believe i need tinymce script added which is working.
Thanks.
Run your own web server using XAMPP (Also Include PHPMyAdmin,MySQL) and use a real IDE, I'd stay away from DreamWeaver. Maybe take a look at PHPStorm.
You don't install that plugin into DW.
As above, you want to use some sort of offline tools like WAMP/XAMPP to setup the server on your local machine then you can look to sort out the plugin you want.
I can vouch for PHPStorm, I use it at work.
