Adding this GPU card to my OcUK system, possible?
24 Nov 2011
Hi,
I have an OcUK's Ultima Tyrannosaur system. Been serving me very well indeed over the years.
Currently there are two NVIDIA Titan cards (each 2 slots width) in the machine, leaves me with two slots free. I would like to add another graphics card to the Asus Maximus IV Extreme-Z motherboard; a NVIDIA Titan-Z and the spec says its 3 slots width. Is this possible? Can I add this to the penultimate slot, leaving I guess it going over and beyond the last slot by one slot width?
Will there be any issues?
Thanks for any help,
Jules
P.S. I am using this for 3D rendering that can use as many GPUs in the machine.
Judging from the silence I guess not.
What about this? Can the Asus Maximus IV Extreme-Z motherboard take a couple of NVIDIA GTX Titan-Z cards?
Jules
just saw this..
as for you're first post. I know all 3 cards need to be the same so this looks like a no.
I would imagine you should be able to run 2 of them in sli on that board just you will need to use the 1st and 3rd pci ports rather than the 1st and 2nd pci ports
