My sister has really bad wifi in her house, to the extent they have to run a cat5 cable from the VM hub to the TV to be able to stream Netflix, etc.
I've tried various things to improve it but none have really worked. So I want to try adding a wired router to the VM hub 3 and using that as a wireless access point...i.e. run a cat5 cable from the VM hub to the router and position it somewhere nearer the centre of the house.
What I'm wondering is, would the VM hub have to be put in modem mode? Or could it be left in router mode? Two reasons for asking this:
1) there are several devices currently plugged directly into the ports on the hub and I believe putting the hub into modem mode deactivates all but the first one...is that correct?
2) if the hub can remain in router mode then presumably both it and the new router will kick out wifi...is that also correct?
In terms of the new router, I was thinking of getting the TP-Link AC1750...seems to be a decent bit of kit that is well reviewed. Can anyone confirm whether these play nicely with the VM hub 3?
Thanks
Thanks
