Additional Memory help?
8 Sep 2010
Hi Guys
I am looking to expand how much memory i have, i've found myself getting more into video editing and recently i've upgraded my Graphics card, this month im looking to add some more memory, i've currently got 6GB Corsair Dominator GT KIT DDR3 (3x2GB) PC3 16000 2000MHz Triple Channel Kit - CMT6GX3M3A2000C8, that under a Ek waterblock, Now i personally dont care about overclocking like i did when i 1st got the ram, i've set everything back to stock, but since the block is fitted ideally any ram i get will either need to fit under the block with the memory Or be compatible with what i have, On corsairs website i've seen they still do the GT series and online i've found a 12GB kit of 3 sticks to up how much i have but i honestly wanted to get you guys thoughts.
i dont want to spend silly money, the kit that is still dominator GT 12GB is £150 and this is the MAX id spend, ive seen some kits on ebay but having recently ordered a processor that was DOA despite the seller saying it was working i've been put off Ebay for a while.
thanks in advance guys
Hi Guys
Please do NOT buy that!
Just purchase 3 x 4gb sticks at the same time, you will most likely get them from the same batch. You can pick up 4GB sticks for less than £20 each!
